| Author |
Message |
wheelin1338 Member
Posted: Sun Mar 12, 2006 5:38 pm Post subject: adding backup lights, questions on wiring |
| i hate the bad back up lights on my XJ especially when offroad and there are trees all around. im going to add two lights on the roof for backup lights as well. i was just wondering what the easiest way to wire these to the backup lights would be, or do you recomend wiring them to a switch? thanks for your input! |
| Back to top |
p_2_biking Member
Posted: Sun Mar 12, 2006 9:11 pm Post subject: |
| i dunno but i myself would just wire it to a switch...seems easier |
| Back to top |
ThePhantum Pissed-Off Admin
Posted: Sun Mar 12, 2006 9:50 pm Post subject: |
The best way to do it would be with a relay. That way you can tap main power from the battery, and have the relay triggered by the reverse lights going on. It's actually easier to do because you don't have to mount a switch either.  _________________
| Back to top |
95sahara Member
Posted: Mon Mar 13, 2006 10:38 am Post subject: |
I did the same thing on my S10 ZR2 that I had, although I mounted two fog lights under the rear bumper instead of on the roof. I wired it up with a relay and three position switch, so I could have them off all the time, on all the time, or just on with the factory backup lights. Here's the diagram I used to wire them up.
 _________________ 06 Rubicon
4" RC sus. lift, 1" PA BL
PICS |
| Back to top |
wheelin1338 Member
Posted: Mon Mar 13, 2006 3:02 pm Post subject: |
| alright thanks for the input, gonna wire that up this weekend! |
| Back to top |
EVANLA_33 Member
Posted: Mon Dec 08, 2008 12:06 pm Post subject: |
| i'd just splice into a your back up lamps on your tail lamps that way it will turn on as soon as u back up. u can buy connector to tap into your existing wires and makes a clean job. just watch the amps on your lights. probley only have a 15 amp fuse but 15 amps are a lot for lights exspecially if u have LEd |
| Back to top |
