2010 SEMA Show
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Jeep News
PostPosted: Sat Nov 13, 2010 1:39 pm    Post subject: 2010 SEMA Show Reply with quote
Some of the new products from the 2010 SEMA Show....
Product: Rugged Ridge Interior Trim Kit for 2007-10 Jeep(R) JK Wrangler
Description: Make your 2007-10 Wrangler stand out with these injection molded plastic interior accents from Rugged Ridge. Injection molded from factory interior for an exact fit.
Company: Omix-Ada/Rugged Ridge
Address: 460 Horizon Drive, Suwanee, GA, 30024, USA
Phone: 770-614-6101
Website: www.omix-ada.com
Part #: 11151.xx
Product: Tire Carrier Linkage for 1976-2011 Jeep
Description: Rugged Ridge Tire Carrier Linkage connects your tire carrier to your tailgate allowing you to open both together in a single fluid motion.
Phone: 770-614-6101
Part #: 11503.9
Product: Deluxe TJ cable shifter
Description: Jeep TJ heavy duty cable shifter designed to correct binding, hard shifts and slipping out of gear that is inherent when lifting a Jeep TJ
Company: Advance Adapters Inc.
Address: 4320 aerotech center way, paso robles, CA, 93446, usa
Phone: 800-350-2223
Website: www.advanceadapters.com
Part #: 715543-231
Product: Radiator/Fan Combination-'87-'05 Wrangler TJ
Description: Flex-a-lite® now offers a direct-fit Flex-a-fit® 2-row radiator and electric fan system for the ’87-’06 Jeep Wranglers (Part #60187). The Wrangler rad/fan combination replaces the stock 1-row radiator with 2-rows for better cooling, and replaces the stock belt-driven fan for more horsepower.
Company: Flex-a-Lite Consolidated
Address: 7213 45th St. Ct East, Fife, WA, 98424, USA
Phone: 253-922-2700
Website: www.flex-a-lite.com
Part #: 60187
Product: Jeep JK 4wd Suspension System
Company: RCD Suspension
Address: 1900 Weld Blvd., Ste 100, El Cajon, CA, 92020, USA
Product: Stainless Steel Jeep Hood Lock
Description: Stainless steel hood lock for 2007-10 Jeep Wranglers. Complete with all hardware for trouble free and secure behind the grill mounting and easy key access.
Company: DuraTrail 2010
Address: 14372 Olde Highway 80 Suite C, El Cajon, CA, 92021, USA
Phone: (619)599-7769
Website: www.duratrail.com
Part #: 1521-22
Product: JK Grab Handle
Description: Jeep TJ, LJ, JK Grab Handles are manufactured from high quality 1.0"" X .083"" DOM tubing. The powder coat finish eliminates corrosion that can occur under extreme elements. The kit includes all hardware necessary for a quick and easy installation; compatible with hard and soft tops.
Company: Poly Performance Manufacturing Inc.
Address: 245 Tank Farm Road Unit L, San Luis Obispo, CA, 93401, United States
Phone: 8057832060
Website: www.polyperformance.com
Part #: PPM-5801
Product: Half Doors for 2007-2011 Jeep® Wrangler
Description: Keep the elements out while maintaining that open air experience. Constructed from paintable impact resistant thermoplastic, mounted to rigid powder coated internal steel frame.
Phone: 770-614-6101
Part #: 11509.01
Product: Alloy USA Axle Tube Seals for 2007-2011 Jeep(R) JK Wrangler & Grande Axle Kits
Description:Keep water, mud and debris from entering your front axle housing. These CNC machined aluminum housings feature two seals to provide double protection from crud.
Phone: 770-614-6101
Part #: 11105
Product: Rugged Ridge Cowl Plate Body Armor for 2007-2011 Jeep(R) JK Wrangler
Description: Protect your cowl from mirror damage whenever your door retainer straps are disconnected and allow your doors to swing free. Fits 2007-2011 JK Wrangler.
Phone: 770-614-6101
Part #: 11651.18
Product: Rancho Jeep TJ New Short Arm 3 1/2 Inch Kit
Description: Rancho Jeep TJ New Short Arm 3 1/2"" Kit that enhances vehicle safety.
Company: Rancho/Dynomax
Address: One International Drive, Monroe, MI, 48161, United States
Phone: 734-384-7804
Website: http://www.gorancho.com/
Part #: RS6424
Product: OCF Jeep Bumpers
Description: MBRP's Off Camber Farications builds off-road's toughest bumpers in full front, stubby front and rear. Bolt-in stock JK driving lights for a clean, professional look.
Company: MBRP Inc.
Address: 315 Old Ferguson Road, Huntsville, , P1H 2J2, Canada
Phone: 1-888-636-7223
Website: www.mbrpautomotive.com
Part #: 130924
Product: Rancho Jeep TJ Rock Gear Bumpers - Front and Rear with Tire Carrier
Product: J4615SSV 4 1/2"" Jeep JK Suspension Lift System with shocks and drive lines.
Company: Performance Accessories/Trailmaster
Product: Jeep Cherokee Replacement Seating
Description: Custom fit replacement seating for 1984-2001 Jeep Cherokee XJ. Does not use adaptor brackets to fit these applications. Four styles to choose from.
Phone: 770-614-6101
Part # 13445.15
Product: 1997-2006 Wrangler Replacement Seats
Description: Custom fit replacement seating for 1997-2006 Jeep Wranglers. Does not use adaptor brackets to fit these applications. Four styles to choose from.
Phone: 770-614-6101
Part #: 13414.09
Product: HighRock 4x4 Narrow Style Front Bumper
Description: Bestop's new Narrow Bumper hits the design points today's Jeep owners are looking for, but it's carefully designed to not hit anything else. Short design eliminates any unnecessary overhang, and will clear any sized tires. There is still room for extraction points.
Company: Bestop Inc.
Address: 2100 W Midway Blvd, Broomfield, CO, 80020, USA
Phone: 800-845-3567
Website: www.Bestop.com
Part #: 42933-01
Description: Direct bolt-on quick change caliper kit designed specifically for late model Jeep CJ. Kit includes three-piston aluminum calipers, performance pads and necessary install hardware.
Company: Stainless Steel Brakes Corp.
Address: 11470 Main road, clarence, NY, 14031, usa
Phone: 18004487722
Website: www.ssbrakes.com
Part #: a189-4
Product: Tube Ends for Jeep XHD Bumpers
Description: Polished stainless or black tube ends for The XHD Jeep modular bumper system.
Phone: 770-614-6101
Part #: 11540.21
Product: All Terrain Fender Flares for Jeep
Description: All-terrain off-road fender flares for 1976-2006 Jeep CJ and Wrangler. Complete four or six-piece kits.
Phone: 770-614-6101
Part #: 11630.1
Product: Flat Fender Flares for 2007-2011 Jeep Wrangler
Description: All-terrain flat fender flares for 2007-2011 Jeep Wranglers. Complete four-piece kit.
Phone: 770-614-6101
Part #: 11620.1
Product: 3.8L TJ Conversion Wiring Harness
Description: Integrated wiring harness to run the Jeep 3.8L in TJ, with OEM fuseblock, gauges and full emissions. An inexpensive upgrade for an aging Jeep.
Company: HotwireAuto a division of Squier Inc.
Address: 256 Polk Rd #256, Mena, AR, 71953, USA
Phone: 479-243-9115
Website: www.hotwireauto.com
Part #: R-0036
Product: Tube Doors for 2007-2011 Jeep® Wrangler
Description: Tube doors help increase visibility when climbing obstacles and trail riding. The doors interchange easily with the factory steel doors and require no body modification.
Phone: 770-614-6101
Part #: 11509.1
Product: 2000-2006 Jeep Wrangler TJ - 4.0 liter V6 Flowmaster Force II cat-back exhaust system
Description: Complete system is 409s stainless steel construction, fully mandrel bent tubing, Super 50 series performance muffler and embossed tip. Includes clamps, hardware & instructions for easy fit.
Company: Flowmaster Inc.-The Exhaust Technology
Address: 100 Stony Point Rd #125, Santa Rosa, CA, 95401, USA
Phone: 800-544-4761
Website: www.Flowmastermufflers.com
Part #: 817491
Product: Jeep JK Oil & Transmission Skid Plate
Description: Protect your Jeep JK oil pan and transmission with our combination skid plate. Protects vulnerable cross over tube of your exhaust system that can get crushed.
Company: Mountain Off Road
Address: 685 Hwy 92, Delta, CO, 81416, USA
Phone: (970)-625-0500
Website: www.mountainoffroad.com
Part #: JKOPSP
Product: Jeep JK Dual Battery Tray
Description: Dual Battery Tray for 2007 and up Jeep Wrangler JK's. Accommodate two Optima series 34, 34/78 and OEM batteries in the stock location.
Part #: JKDBT0709
Product: Rally Front Bumper
Description: This is our new Rally Front Bumper. This new aerodynamics design can be custom make to your spec (color, extra lighthing extra holes, etc) Also a Ultima Bumper Style is avaialble for new 2011 CHEVY, DODGE, FORD, GMC, JEEP, TOYOTA and NISSAN.
Company: Viper 4X4 LLC
Address: 6500 N.W. 77 ct, miami, FL, 33166, USA
Phone: 305-468-9818
Website: WWW.VPR4X4.COM
Part #: vpr201
Product: deluxe jk cable shifter
Description: Heavy duty cable operated system designed for the Jeep off roader who is constantly shifting the transfer case in and out of its various ranges shifts his transfer case frequently. The improved cable and mounting system offers both a durable and dependable system that is free of the easily worn out factory shifting components.
Phone: 800-350-2223
Part #: 715543-241
Product: Jeep WK Camber/Caster Adjustable Ball Joint
Description: Jeep WK/XK Camber/Caster Adjustable Ball Joint. Offset design allows an additional 1-degree of positive or negative camber adjustment. ProRYDE Suspension Systems Booth #30163
Company: ProRYDE Suspension Systems
Address: 6100 Baker Road, Minnetonka, MN, 55345, USA
Phone: 1-888-813-RYDE (7933)
Website: www.ProRYDE.com
Part #: 44-2493
Product: Steel D-Window Wheels for 1955-06 Jeep® Wrangler & CJ
Description: Rugged Ridge steel wheels are stamped from heavy-gauge steel and powder coated with a durable black finish. Engineered, tested and certified.
Phone: 770-614-6101
Part #: 15500.1
Product: Cat Back Exhaust Kits For Jeep
Description: Cat-Back Exhaust Systems for Jeep. Includes an overbuilt heavy duty off-road muffler.
Address:460 Horizon Drive, Suwanee, GA, 30024, USA
Phone: 770-614-6101
Part #: 17606.55
Product: Storage Bumper Ends for Jeep XHD Bumpers
Description: Storage ends for The XHD Jeep Modular Bumper System. Fits all 2007-2011 Jeep Wranglers.
Phone: 770-614-6101
Part #: 11540.22
Product: Overhead Storage Console for 1987-11 Jeep® Wrangler
Description: The Rugged Ridge Overhead Storage Console is a complete storage solution for Jeep® Wrangler. It turns the area underneath the top into usable storage space.
Phone: 770-614-6101
Part #: 13551.14
Product: Rugged Ridge Hood Mount Halogen Light Kit for Jeep(R) JK Wrangler
Description: Rugged Ridge offers an innovative way to mount two offroad driving lights to your JK Wrangler with the Hood Mount Light Kit. A bright idea.
Phone: 770-614-6101
Part #: 15207.7
Product: Alloy USA Wheel Spacers for 2007-11 Jeep® Wrangler
Description: Wheel spacers that move wheels out to help fit aftermarket wheels and wider tires while creating a wider stance with extra stability.
Phone: 770-614-6101
Part #: 11300
Product: Dual Battery Tray for 2007-11 Jeep® Wrangler
Description: The dual battery kit is designed to mount two batteries in place of the factory single battery location.
Phone: 770-614-6101
Part #: 11214.53
Product: Rancho Jeep TJ New Sport 3 1/2 Inch Kit
Description: Rancho Jeep TJ New Sport 3 1/2"" Kit that enhances vehicle safety.
Phone: 734-384-7804
Part #: RS6501
Product: Jeep Wrangler TJ/LJ Sway Bar Set
Description: Jeep TJ/LJ adjustable sway bar system replaces factory sway bars with front sway bar and quick disconnect endlinks plus rear sway bar with a tuned to match / compliment the front sway bar.
Company: Hellwig Products Co.
Address: 16237 Ave 296, Visalia, CA, 93292, USA
Phone: 5597347451
Website: www.hellwigproducts.com
Part #: 77870
Product: Jeep JK Muffler Skid Plate
Description: Protect your Jeep JK Muffler with our 3/16"" muffler skid plate. Easy bolt on construction and powder coated black. 2007 to current
Part #: JKMSP
Product: 07-10 Jeep Wrangler JK 2"" - 2.5"" LOWjacker Lowering Sport Coils
Description: LOWjacker Sport Coils for 07-10 Jeep JK! Uniquely designed progressive rate coil springs lower the center of gravity 2-2.5” while providing improved handling and cornering characteristics.
Company: Skyjacker Suspensions
Address: 212 Stevenson Street, West Monroe, LA, 71292, USA
Phone: 318-388-0816
Website: www.skyjacker.com
Part #: LOWJK024
Product: Jeep JK Freedom Top Storage Rack
Description: Keep your Jeep JK Freedom tops looking new and scratch free. Stores the Freedom top upright behind the rear seat or lay down.
Part #: JKFTR
Product: Jeep Cold Air Intake
Description: Jeep Cold Air Intake (1997-2006 Wrangler TJ 4.0L 6 cylinder). Featuring high-quality components: polished aluminum tubes, washable/reusable, hpR Filters, EPDM grommets and connectors and stainless steel T-bolt hose clamps.
Company: Spectre Performance
Address: 1720 S. Carlos Avenue, Ontario, CA, 91761, U.S.A.
Phone: (909) 673-9800
Website: www.spectreperformance.com
Part #: 9943
Product: Hood Lock
Description: Rampage introduces a custom Jeep Hood lock assembly with stainless/brass components, adjustable tension and a durable powder coat finish
Company: Rampage Products
Address: 22420 Temescal Canyon Road, Unit C, Corona, CA, 92883, USA
Phone: 951-277-4949
Website: www.rampageproducts.com
Part #: 74xxx
Product: King Shocks Bolt-On Adjustable Jeep JK Shock Kits
Description: Premium quality, owner rebuildable, bolt-on, Jeep JK performance shock upgrade kits with adjustable Wide Range Compression adjustment for stock height and aftermarket lifted suspensions.
Company: King Shocks
Address: 12842 Joy Street, Garden Grove, CA, 92840, USA
Phone: 714-530-8701
Website: www.kingshocks.com
Product: JK Winch Mount
Description: Made specifically for the Jeep Wrangler 07-2011 Stock Bumper, finished in Black Powdercoat, for long-lasting durability. Mounting hardware included. Supports up to a Smittybilt 10000lb winch. Made from 1/4"" Steel.
Company: Pro Comp/Smittybilt
Address: 400 West Artesia Blvd, Compton, CA, 90220, LA
Phone: 888-717-5797
Website: www.Smittybilt.com
Part #: 2804
Product: Sun Visor Covers for 2007-11 Jeep® Wrangler
Description: Instantly turn the plastic sun visors on your 2007-2011 Wrangler into usable storage space while getting a clean new look with Custom Visor Covers.
Phone: 770-614-6101
Part #: 13305.08
Product: 2007-2011 Jeep Wrangler Throttle Body Spacer
Description: Billet Aluminum Throttle Body Spacer for 2007-2011 Jeep Wrangler, 3.8L.
Phone: 770-614-6101
Part #: 17755.02
Product: TrekStep for Jeep Wrangler
Description: A spring loaded step that easily extends down with the push of a foot and retracts up to store securely under the rear bumper when not in use.
Phone: 800-845-3567
Part #: 45299-15
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Jeep News All times are GMT - 8 Hours
