Removing body kit
baylorhenry
PostPosted: Thu Aug 19, 2010 7:34 pm    Post subject: Removing body kit Reply with quote
Hey guys,
I'm a newb here. I recently posted photos from a trip down to big bend:
http://jeephorizons.com/phpbb/viewtopic.php?t=16153
Here's the thing... My TJ came with an honest to God disgustingly awful body kit... nothing wrong with it if you're into that stuff, but man it's a useless waste of time to me because 1. I get a bumpier ride, 2. I get a weird gap between the body and the chassis, 3. it accomplishes nothing but to put larger bling tires on.
questions is: How do I remove this? I think there are about 6-8 black nylon spacers on it and I don't know how I should go about to remove them cause I don't have the OEM bolts. I want this crap off so I can put a suspension kit on and actually have a trail ride-able jeep!
thanks in advance.
Henry
PostPosted: Fri Aug 20, 2010 9:54 am    Post subject: Reply with quote
What size body lift does it have. Different heights have different mods that need to be done to install the kit. You will have to undo these modifications.
baylorhenry
PostPosted: Fri Aug 20, 2010 5:23 pm    Post subject: Reply with quote
It is a 3 inch lift. I count 10 spacers installed on the jeep
PostPosted: Fri Aug 20, 2010 7:46 pm    Post subject: Reply with quote
I was going to explain the disassembly off the top of my head, but this will be easier. Follow in reverse. These may not be the same brand lift that you have, but they are generally all the same.
If you run into a snag, feel free to ask questions.
http://www.pdfoo.com/jeep/160-16118-pdf.html
http://www.bds-suspension.com/pdfs/9292-9392.pdf
baylorhenry
PostPosted: Tue Aug 24, 2010 7:18 pm    Post subject: Reply with quote
so...
1 the nylon spacers/bolts
2 steering column
3 fuel tube
4 fan shroud(mine is an electric fan... doesn't look like it's trimmed
anything else?
PostPosted: Wed Aug 25, 2010 7:23 am    Post subject: Reply with quote
Transmission linkage
T-case linkage
Radiator brackets
