Code PO123
motownguy
PostPosted: Wed Jul 14, 2010 12:29 pm    Post subject: Code PO123 Reply with quote
Hi, I've got a 2001 Grand Cherokee, 4.0 with 123,000 miles. I thought my transmission (automatic) was going because while driving, I could feel it slip, and especially when getting off the freeway, it would not shift into 2nd, I'd have to pull off the road and re-start. Somebody put a meter on it and it showed a code PO123 which is the throttle positioning sensor? Is that something I can do myself or should an experienc mechanic do it? I just do basics around my cars, not into heavy-duty stuff, but if it's something that just unscrews and screws in, maybe I can do it.
Thank you.
Toliver09
PostPosted: Sat Feb 12, 2011 7:17 pm    Post subject: Reply with quote
The throttle position sensor is located on the throttle body, you can remove the two bolts that hold it on with an allen wrench, but a star head allen wrench is the correct tool for it. If I remember correctly it is a metric size 15. Very easy to do yourself.
