looking for 2006 GC Limited Torque Specs (suspension)
sheac
PostPosted: Fri Apr 02, 2010 5:11 pm    Post subject: looking for 2006 GC Limited Torque Specs (suspension) Reply with quote
hey all, new to the forums. have a 2006 Grand Cherokee Limited 5.7L 4x4 and have been looking for weeks for torque specs for anything on it, but mainly the suspension. putting a 2" lift on it and want to make sure i have all the nuts/bolts and linkage torqued correctly. can anyone help me?
Thanks
knocklehead
PostPosted: Sat Jun 19, 2010 9:29 am    Post subject: Re: looking for 2006 GC Limited Torque Specs (suspension) Reply with quote
control arms
UCA axle 55 ft lbs
UCA frame 66 ft lbs
LCA axle 85 ft lbs
LCA frame 85 ft lbs
Leaf Springs
U-bolt nuts 52 ft lbs
front pivot bolt 115 ft lbs
upper shackle bolt 115 ft lbs
Lower shackle bolt 80 ft lbs
Trac bar
Ball stud 60 ft lbs
Axle shaft 74 ft lbs
