94 Grand Cherokee - stalling issues..
MommaCat06
PostPosted: Fri Apr 02, 2010 10:40 am    Post subject: 94 Grand Cherokee - stalling issues.. Reply with quote
I have a '94 Jeep Grand Cherokee, V8, about 155,000 miles. Having problems with it stalling. It will start, most of the time, but as soon as you go to take it out of park, it will stall. Check engine light comes on right before it stalls. Sometimes when you go to stop at a stop light or sign, the rpm jumps up and drops back down, then it stalls. Just had a full tune-up done as well as an oil change and fuel filter replacement. We checked it with a gage and it's at 32 on the fuel pressure, which it's suppose to be 31 -39. Anybody have any ideas?
RussellRowell
PostPosted: Sat Apr 10, 2010 7:19 pm    Post subject: Reply with quote
Sounds like you could have a vacuum leak. If you had your spark plug wires replaced. I would check carefully around the routing of the wires along the top of your valve covers. There could be a broken orifice or vacuum line. GL
1994 w327k
