Will a 97 cherokee Trans fit a 98 wrangler
Darbster
PostPosted: Sun Dec 06, 2009 11:59 am    Post subject: Will a 97 cherokee Trans fit a 98 wrangler Reply with quote
I'm changing out my 2.5 to a 4.6l golen, i need everything for it from the MM all the way back to the t-case....was wondering if you could use everything from a 97 cherokee sport to drop into the 98 TJ? i know you will atleast need to cut down the drive shafts, but will everything else work to include the ECU and wiring harness?!? Really could use some help guyz
James
