| Author |
Message |
sdoroski12 Member
Posted: Tue Oct 06, 2009 7:54 am Post subject: Tips to change door and hood hinges? |
| I bought the stainless hinges to replace my other rusty ones. Problem is I can't figure out if it is an allen wrench or some other tool? Any ideas???? I obviuosly don't want to strip it and like everything they are rusted on or really stuck... any other tips to make this easier are appreciated |
| Back to top |
provo Member
Posted: Tue Oct 06, 2009 5:31 pm Post subject: |
| on my 01 they are torx bolts |
| Back to top |
Orangeamc13 Got Rev Limiter?
Joined: 20 Feb 2006 Location: East Springfield, Massachusetts - U.S.A.
Posted: Wed Oct 07, 2009 7:43 am Post subject: |
If it's star shaped, it's a torx. _________________
| Back to top |
neon22 Member
Posted: Thu Nov 05, 2009 8:27 pm Post subject: |
| i bought new door hinges and the bolts that came with them were allen style. but the ones that came with the kit were really cheap metal and striped all the time, so i went to tsc and bought fully stainless steel normal six sided style bolds and they work great. the stock bolts on the tj are torx for sure though. they should look like a star shape. if they are dont use an allen wrench or you will strip them for sure |
| Back to top |
wolfen Member
Posted: Sun Nov 22, 2009 7:11 am Post subject: |
Hi. I'm new on here, and this is my first post, but I have to do it here first since I have a way to help.
SS hinges are the best way to go , However the original bolts are not SS, if they are rusted, step one is to coat them with a penetrating oil preferably Wintergreen. The bolts are torx, mine are T-50's. Chances are they are going to strip when you try to remove them, so what you might end up doing is like what I ended up doing, I had to drill the bolt head off, then drill through the shaft and install SS crosspiece ( Philips) screws,
try jiggling the torx bit back and forth also, this might break it loose |
| Back to top |
