Auto Transmission fluid capacity
AZSobo
PostPosted: Mon Feb 02, 2009 10:30 am    Post subject: Auto Transmission fluid capacity Reply with quote
I have a 2001 TJ that I need to change all the fluids for - the manual does not give capacities just type recommendations.
I found everything I needed at http://www.getahelmet.com/jeeps/maint/fluids/ except for the automatic transmission. (excellent site by the way)
He does have specs for the 545RFE Automatic Transmission but I'm not sure if the fluid caps. are the same - 6.55 Quarts listed.
Is that about right?
Thanks
Jeff
PostPosted: Mon Feb 02, 2009 10:37 am    Post subject: Reply with quote
From the factory service manual, it should be 4.0 quarts for a service fill.
AZSobo
PostPosted: Mon Feb 02, 2009 10:45 am    Post subject: Reply with quote
Thanks,
I didn't specify - changing filter too
Jeff
PostPosted: Mon Feb 02, 2009 12:43 pm    Post subject: Reply with quote
Should be the same, the larger quantity is if you're rebuilding and to account for the torque converter and cooler.
AZSobo
PostPosted: Mon Feb 02, 2009 2:16 pm    Post subject: Reply with quote
Gotcha - Thanks!
