Upgrade to distributor-less ignition?
azcat
Location: AZ - It's a dry heat, but so's a blast furnace
PostPosted: Thu Jan 01, 2009 3:54 pm    Post subject: Upgrade to distributor-less ignition? Reply with quote
I was thinking about swapping the stock ignition system in my '99 4.0L TJ with a distribuotr-less one from a newer model. Not looking so much for HP gains, mostly reliability.
Pros & cons? How involved would this be? This is also my DD.
PostPosted: Mon Jan 05, 2009 7:39 pm    Post subject: Reply with quote
coil overs aren't cheap . pro's no water in the distributor , no plug wires for resistance .
i never really had a problem with my distributor on my 4.0L actually put a distributor cover off a 91 ford escort gt after that i never seemed to get water in there .
azcat
PostPosted: Tue Jan 06, 2009 8:18 pm    Post subject: Reply with quote
Thanks for the reply, Brad. I haven't had any issues with water in the distributor, especially here in So. Arizona. Very Happy I even made a couple of stream crossings that were up to the fenders with no problems.
Probably the cost wouldn't be worth the minimal benefit.
