Author |
Message |
Clifford Member
Posted: Fri Jan 26, 2007 5:16 am Post subject: Anybody install a t-case drop kit? |
I started trying to install a Skyjacker t-case drop yesterday. Got 5 of the 6 bolts out of the t-case skid plate, and the last bolt broke on me. Now the nut up inside the frame is just spinning with the bolt. How the heck am I supposed to get it out?? |
Back to top |
ehirner Moderator
Posted: Fri Jan 26, 2007 2:31 pm Post subject: |
Support the drivetrain using a jack.
Cut the bolt head off.
Drop the skid.
Push the bolt and attached nut up into the frame rail.
Weld the appropriate sized nut to a large fender washer creating a flanged nut.
Skid the flange nut, nut side up, into the hole.
Weld the flange (the washer) to the frame rail.
When you put the bolt back in, coat them with antiseize. _________________ 04 Unlimited |
Back to top |
Clifford Member
Posted: Tue Jan 30, 2007 10:10 am Post subject: |
Thanks for the tips.  |
Back to top |
